Administrators Koach Posted January 24, 2011 Administrators Report Share Posted January 24, 2011 Auto +q works again! I've had alot of people ask for a way to Auto +q their room members. But without using a script, there was no way to do it. Now we have a way! First, you'll have to turn off XOP for your room. This means things like AOP, SOP, HOP, etc will no longer work. Instead, you'll use ACCESS to set user LEVELs. Here's how to do it (you will substitute your room name for #koachsworkshop) /cs set #koachsworkshop xop off Next, you'll need to set the level for each of your ops/hosts, etc. Here are some default levels you can use and you can customize them too Level: 9999 Type: Auto Owner XOP (old): there was previously no way Mode +q Level: 10 Type: Auto Admin XOP (old): SOP Mode: +a Level: 5 Type: Auto Op XOP (old): AOP Mode: +o Level: 4 Type: Auto HalfOp XOP (old): HOP Mode: +h Level: 3 Type: Auto Voice XOP (old): VOP Mode: +v Here are a few examples. To set nooblet to auto owner in #KoachsWorkShop: /cs access #koachsworkshop add nooblet 9999 To set nooblet to auto op in #KoachsWorkShop: /cs access #koachsworkshop add nooblet 5 For a complete description of each level type: /cs help levels desc For an example of customizing the room LEVELS: http://www.koach.com/forum/index.php?/topic/267-how-to-set-levels-in-your-chat-room/ For a list of levels set in your room: /cs levels #koachsworkshop list For more detailed information about ChanServ: http://www.koach.com/anope/en_us/ChanServ.php Let me know if you have more questions Koach Important reminder! Never give your channel password to another person. If you do, you are giving them ownership of the room and you may not be able to get it back! Link to comment Share on other sites More sharing options...
Oak Posted December 11, 2012 Report Share Posted December 11, 2012 i know this is old now but i keep getting "ChanServ- Channel access lists may only contain registered nicknames." with xop off /cs access #team\boak add ADDRESS 9999 ..Owner ...Add:/cs access # add $address($1,1) 9999 ...Delete:/cs access # del $address($1,1) 9999 ...List:/cs access # lis cant i add a mask over just a nickname? Link to comment Share on other sites More sharing options...
Administrators Koach Posted December 14, 2012 Author Administrators Report Share Posted December 14, 2012 Sorry Oak, I just saw this post. I don't think you can use a mask. This auto q module works with Services and Nickserv and Chanserv only recognize people that have registered a nick. But, I'd have to test this to be sure. I'll try to check it later. Link to comment Share on other sites More sharing options...
