Stormy Posted January 25, 2011 Report Share Posted January 25, 2011 on *:NOTICE:*:*: { if (Nickserv!*service* iswm $fulladdress) && (Koach.com == $network) && (*nickname is registered* iswm $1-) { identify ********** } } put the above in remotes and do the following ********** <---- replace that with your password Back to top Link to comment Share on other sites More sharing options...
Administrators Koach Posted July 30, 2011 Administrators Report Share Posted July 30, 2011 Jas has improved this code to work with all nicks (registered and grouped nicks). Thanks jas on *:NOTICE:*:*: { if (($network == koach.com) && (Nickserv!*service* iswm $fulladdress) && (*please choose* iswm $1-)) { ns identify ****** } } Replace the ****** with your nickserv pass. Link to comment Share on other sites More sharing options...
Chain Posted October 22, 2020 Report Share Posted October 22, 2020 on *:connect:{ .msg NickServ IDENTIFY urpasshere } Link to comment Share on other sites More sharing options...
Chain Posted October 22, 2020 Report Share Posted October 22, 2020 menu * { Auto Identify:/dialog -m _auto_ident _auto_ident } dialog -l _auto_ident { title "Auto Identify" size -1 -1 92 96 option dbu list 1, 2 8 89 34, size vsbar box "", 2, 0 0 92 87 edit "", 3, 3 43 50 10, disable autohs edit "", 4, 3 53 50 10, disable pass autohs text "Nickname", 5, 53 45 36 8, right text "Password", 6, 53 55 36 8, right button "Add", 8, 2 73 16 12, disable button "Edit", 9, 39 73 17 12, disable button "Cancel", 10, 56 73 33 12, disable button "Del", 20, 18 73 21 12, disable edit "", 21, 3 63 50 10, disable autohs text "Network", 22, 53 65 36 8, right text "Developed by Nikolas/updated by Chain", 23, 1 87 90 8, disable center } on *:dialog:_auto_ident:*:*:{ if ($devent == init) { _auto_ident_init } elseif ($devent == sclick) { if ($did == 8) { if (!$hget(_auto_ident,$+($did($dname,3).text,.,$did($dname,21).text))) { hadd -m _auto_ident $+($did($dname,3).text,.,$did($dname,21).text) $did($dname,4).text did -r $dname 3,4,21 did -b $dname 8 _auto_ident_refresh _auto_ident_save } else { noop $input("This Nickname is allready added on your list on the same network,o,Auto Identify) } } elseif ($did == 1) && ($did($dname,1).seltext) { set %_auto_ident_edit 1 var %name = $gettok($did($dname,1).seltext,1,32) var %network = $remove($gettok($did($dname,1).seltext,2,32),$chr(40),$chr(41)) did -ra $dname 3 %name did -ra $dname 4 $+($chr(1),$chr(2),$chr(3),$chr(4)) did -ra $dname 21 %network did -e $dname 9,10,4,20 did -b $dname 3,8 } elseif ($did == 9) { hadd -m _auto_ident $+($did($dname,3).text,.,$did($dname,21).text) $iif($did($dname,4).text == $+($chr(1),$chr(2),$chr(3),$chr(4)),$hget(_auto_ident,$did($dname,3).text),$v1)) did -r $dname 3,4,21 | did -b $dname 9,10,8,20 | did -e $dname 3 | did -u $dname 1 set %_auto_ident_edit 0 _auto_ident_refresh _auto_ident_save } elseif ($did == 10) { did -r $dname 3,4,21 did -b $dname 9,10,8,20 did -e $dname 3 did -u $dname 1 set %_auto_ident_edit 0 } elseif ($did == 20) { hdel _auto_ident $+($did($dname,3).text,.,$did($dname,21).text) did -r $dname 3,4,21 did -b $dname 9,10,8,20 did -e $dname 3 did -u $dname 1 set %_auto_ident_edit 0 _auto_ident_refresh _auto_ident_save } } elseif ($devent == edit) { if ($did($dname,3).text) && ($did($dname,4).text) && ($did($dname,21).text) && (%_auto_ident_edit != 1) { did -e $dname 8 } else { did -b $dname 8 } } } alias -l _auto_ident_init { if (!$hget(_auto_ident)) hmake _auto_ident if ($exists(_auto_ident.hsh)) hload _auto_ident _auto_ident.hsh else hsave _auto_ident _auto_ident.hsh if ($dialog(_auto_ident)) { did -e _auto_ident 3,4,21 _auto_ident_refresh } } alias -l _auto_ident_refresh { did -r _auto_ident 1 var %i = 1 var %e = $hfind(_auto_ident,*,0,w) while (%i <= %e) { var %entry = $hfind(_auto_ident,*,%i,w) var %value = $hget(_auto_ident,%entry) did -a _auto_ident 1 $gettok(%entry,1,46) ( $+ $gettok(%entry,2,46) $+ ) inc %i } } alias -l _auto_ident_save { hsave _auto_ident _auto_ident.hsh } on *:notice:*:?:{ if ($nick == NickServ) && (*This nickname is registered and protected* iswm $1-) { if (!$hget(_auto_ident)) { _auto_ident_init } .msg NickServ identify $$hget(_auto_ident,$+($me,.,$network)) } } This add-on allows you to store your identifies for every nick you have on a network you will specify. The passwords are getting stored in plain text mode, but this wont be a problem. This add-on creates a file called _auto_ident.hsh containing the data of your Nicknames and Identifies on each network. Link to comment Share on other sites More sharing options...
Chain Posted October 22, 2020 Report Share Posted October 22, 2020 Or simple way of doing it is like this on *:CONNECT:{ if ($network == chat3.koach.com) { msg NickServ identify <password> } if ($network == irc.rizon.org) { msg NickServ identify <password> } if ($network == irc.coders-irc.net) { msg NickServ identify <password> } } Link to comment Share on other sites More sharing options...
Chain Posted October 22, 2020 Report Share Posted October 22, 2020 so many options, so many ways you can play with it! Link to comment Share on other sites More sharing options...
Odd Posted November 6, 2020 Report Share Posted November 6, 2020 I use the simple version but I'll try the not simple version to see what all of that code means because I haven't got the slightest clue 😅 Link to comment Share on other sites More sharing options...
Administrators Koach Posted November 12, 2020 Administrators Report Share Posted November 12, 2020 Thanks Chain Link to comment Share on other sites More sharing options...
